Jani,
I'll offer some advice about the cooling system.
there is a good probability that your Longchanmp's motor has the wrong thermostat installed. this is a very common problem even here in the states. Auto parts stores, Ford dealerships and even Pantera vendors dispense the incorrect thermostat. The Cleveland thermostat is different than the Windsor (351W) thermostat, but most parts vendors dispense the Windsor thermostat for 351C applications. The correct thermostat is a Robertshaw model 333-180. This is a picture of the Cleveland thermostat:
I don't know where to advise you to purchase one in Europe. They are available via mail order from Summit Racing, stock number BRA-333-180 (Summit will refer to it as a Flow Kooler thermostat).
Drain the radiator and visually inspect the core for scale deposits, if scale is visible the radiator will require chemical cleaning or replacement.
Another common error with 351C maintenance is the improper orientation of the head gaskets during assembly of the motor. This can be detected by a gurgling & surging sound coming from the motor as it heats up.
Assuming the head gaskets are installed properly, a good clean radiator and the proper thermostat should resolve any overheating problems. If the car continues to overheat you can increase coolant flow with an Edelbrock water pump. This pump is unique in that it employs a cast, curved vane impellar which pumps coolant more efficiently than the usual stamped steel "paddle" type of impellar.
A final solution to resolve overheating problems would be to install a new radiator with a more efficiently designed core. Modern radiator cores have fewer rows composed of wider tubes (33 - 38 mm wide) for less restriction to coolant flow and a better fin design for improved air flow.
