I want those mounts!!!! Make a set to fit the stock location and I'm all in.
Steve
Looking good Scott! Keep the updates coming!
Another Pantera with a Che
Shucks I hit the button prematurely. What I meant to say was:
Another Pantera with a Chevy engine.
http://www.ebay.com/itm/Other-...90&pt=US_Cars_Trucks
I just spit up some box wine. even that couldn't numb me. I've done some distasteful things in life, but they've got me beat.
quote:Engine Swap Build Log
This is what this topic is about. For those interested in the SACC Restorations LS9 Build.
For those that want to start a topic to debate Chevy engines, please start your own thread.
Thank you...
quote:Originally posted by Bosswrench:
Big-block conversions move the ZF back FOUR full inches with no known halfshaft problems. Biggest problem for most engines is the oil pan notch vs the under-engine crossmember. But some LS engines are dry-sump with shallow pans and can mount high enough that clearance is not an issue.
As far as the 'Chevy-in-a-Ford' thing, its well known that GM "borrowed" designs from a number of sources in building the LS series engines, including the hot-rodders. Some hard parts adapt almost directly from LS to thirty-years-older 351-Cs! Just look at them as modernized Clevelands, or what Ford might have done had they not thrown the Cleveland design in the trash in '74 & kept the Windsor truck engines.
I will say this, that is one heck of a compact engine package and really fits the chassis well.
There are 1000hp axle shafts available now, so that shouldn't be a problem.
Being the paranoid that I am I would immediately be concerned about the supercharger with the ZF since all published information and quotes from Butfoy state that it is a hard 550ft-lb torque limit.
Actually Quella proved with doing at least three 427 Ford installs into the Pantera that isn't necessarily a problem though.
There's no question the ZF held and is holding up fine with those installs.
The only thing aesthetically that bothers me here now is the coil packs sitting on the valve covers.
I acknowledge that I'm probably in the minority on that anyway as many will say form follows function and therefore they are beautiful?
There's no question that the fabricated parts like the engine and trans mounts are coming out beautifully so I can compensate by lusting for them.
I think ultimately what will set the finished install off is the headers? Those and the supercharger all tucked in like that are just going to be like a Tiffany diamond necklace hanging over the cleavage of a set of 36DD's.
I try not to stare in situations like that but most understand that it is a hopeless situation and that I am only being a moth attracted uncontrollably to the flame?
So far so good. I'm already working on my safety harness to keep me from falling into the crevice between those babies on this car.
It's seems inevitable though that you'll find me with my head stuck in there between...the header tubes! Just checking for fit you understand. Purely scientifically.
Beautiful Chris. Can't wait to see it finished.
I personally love this swap and can't wait to see the final product.
As for Doug's aesthetic concern, I have often thought that the coil packs do take a little away from the look of the engine. Interestingly, I have seen remote mounts for the coil packs on the LS3 but do not know if they make them for the LS7. I have heard mixed reviews on these. There is also a company making a cover that looks like old school big block valve covers to hide them on the LS3.
I still would like to have that old, junk, worn out LS3 they are replacing for my Pantera.
Keep up the good work Chris and Scott.
Devin
Devin
quote:This is what this topic is about. For those interested in the SACC Restorations LS9 Build.For those that want to start a topic to debate Chevy engines, please start your own thread. Thank you...
Sorry Scott I posted the ebay ad to show that there are others. Personally I don't like the approach the ebay car took. Your build will be fantactically functional. Looking foreword to seeing it done.
Scott, Any updates?
Thanks everyone for all of the positive feedback. We like doing the swap for our own enjoyment, but it's great when we get good feedback from other people that like our work as well.
Sorry for the lack of updates too, guys. We've been really busy tackling a bunch of things with the engine swap, including a couple of issues we've had to fix, and of course Easter this last weekend (which we hope everyone had a good one!)
Anywho, over the past few weeks we've been working hard in getting the engine mated with the transmission which turned into a much bigger project than we had originally anticipated. We began by installing the flywheel on the engine and it fit great! Then, we decided to attempt to polish our aluminum bellhousing and boy did that turn into a long process. We spent almost an entire day polishing that sucker and it came out pretty awesome. It could use a bit more work and elbow grease but it's good as a start. We also fabricated a brand new clutch mount that bolts directly to the bellhousing.
The next weekend we installed the discs and pressure plate onto the engine and that went very well. It fit perfect and looked bitchin'! But when we tried mounting the bellhousing onto the engine, we ran into an issue. Due to the new dual-disc and pressure plate design, the depth was increased from what we ran with the LS3. It was incredibly close to fitting, but it was off enough to cause us an issue. So to combat this issue, we ended up countersinking all the bolts on the clutch and the bellhousing so we didn't have any issues with it hitting the bellhousing.
After doing that, we still had a few areas where the clearance was too close for comfort. So what were we to do? Well of course; we had to figure out a way to mount the bellhousing on our machine to machine the edge down where it was hitting.
After spending a couple hours machining, we finally got the bellhousing to fit.
Once we got it to fit, it was time to mate the engine and the transmission.
It's been a super busy past couple of weeks but we are finally going to get the engine and transmission into the car for the final time.
Oh and I also forgot to mention that we got the fuel tank out of the car as well. We are going with a new fuel system design (very similar to what the ZR1 Corvette uses). Basically we will have a 12-15 gallon tank in the trunk area with a smaller (2-5 gallon) tank near the engine that we use as the feed for the engine. This works very similar to a dry sump oil system that makes sure the engine gets a constant flow of fuel. (It also betters the cars weight distribution and makes the engine compartment a little bit prettier and more symmetrical, because hey, everyone loves symmetry
). And we figured, it's a purpose built sports car; we don't need trunk space.
Check out the full gallery on our blog
Nice update Chris!!! Thanks!!!
Nice project Chris,
I am really interested in your cabel shifter system. Do have some more information that?
grtz Arno
grtz Arno
This project is very interesting.
A long time ago, I was interested in doing a Crown V-8 converion into a Corvair.
I never liked the small block Chevy engine alternatives available.
That was also before I was aware of a ZF.
This drivetrain, if money and value invested was not a consideration, is a perfect solution to that one.
I always noticed the similarities in the the tubs between the two cars as well.
I haven't even heard of one of the Corv8's even still being around, but it was an interesting thought?
I never thought you'd have this much work to do on the bellhousing but the challenge looks like fun.
Thanks for posting. I'm enjoying the thread.
quote:Originally posted by Dago:
Nice project Chris,
grtz Arno
Thanks a lot Arno! Your engine looks very nice too! We will have more info on the cable shifter very soon. Hang tight
Thanks Doug!
This weekend we got quite a bit more work done on the car. We got a new support piece installed to strengthen the side of the engine hatch opening area where we cut.
Check out the video of my dad welding it in
After we got the support piece in, we decided to get our new firewall panels installed. We used to have diamond plate on our firewall but with the new engine, we decided to go with a different design. We got a brushed stainless steel plate that turned out awesome. We finished both sides and were debating whether or not to do a top piece (since the engine will cover it) but since we have left over material, we're going to finish it off and do a top piece.
After we get the top piece in, we will be putting the motor in!
View more pics here
View more pics here
View more pics here
Gotta make Dad earn his keep!
I did the brushed stainless bulkhead and engine covers in my car too. I have never been sorry about that at all. I think they are a classy touch to add to any Pantera.
They can always be taken out. They are just held in by a few strategically placed stainless sheet metal screws.
I know you will love yours. They help so much in keeping the engine bay clean and presentable.
Don't use Brillo pads on them though. For some inexplicable reason the pads transfer steel to the stainless and that will leave rust stains.
Very weird if you ask me. Wipe them down with Windex like you would do with the glass and the chrome and a paper towel.
I've worked before with stainless sheet and have found that in the long run you, anyone, is better off putting 90 degree bent edges on the sheets. For one thing it hides the cut edges but more importantly if you don't the sheets have a tendency of developing ripples that you can see in the surfaces. Especially when they are exposed to heat/cool cycles. Just my opinion of a better way to do them and you definitely need a brake to do the bends on.
In my case that fit into wanting to install more firewall insulation because it created a space to put it and a shield to protect it.
Now stop talking and get back to work so we can see the finished product.
Dad has got to weld up those headers.
Sign In To Reply
