i am reinstalling the front suspension and want to add more camber in the alignment .existing caster is 2.6 degrees neg. the shims are all in front of the ball joint. i also have urethane bushings in the suspension . should i modify the bushings or the ball joint or both?or a combination of upper ball joint /lower a arm? if i do the ball joint what is the maximum material removable before i see 'grease'?
