New all Aluminum 393 stroker engine. New Crower crank, Carillo Rods, JE Pistons, Isky roller cam, Fox body pan, oil pump, pickup, ported virgin Ford C302B heads (Cleveland style), used Fontana 9.200 deck height block. 10.5:1 compression with 65cc heads....
Aluminum short block is together, heads are disassembled. These parts are needed to complete engine..Fontana front cover, head studs, intake, rockers, solid roller lifters, timing chain, valve covers, carb, gaskets and distributor ~ $7,900 as is,.....
Completed engine, less carb, but including dynoing ~ $10,750
Short block only ~ $5,200
Heads only ~ $3,400
Remember, everything but the aluminum block is new.....This will be a 650 HP engine when finished.
Specifics upon request....
Gary - grr456@aol.com
