Random question; when replacing the cam shaft do you need to lift the engine, or can you access it from the hatch inside the passenger compartment?
quote:Originally posted by 72pantera:
Thanks for all the insight. I clearly have some thinking to do.
Doug, just wondering what cams you are running now?
quote:Originally posted by Wasatch Cat:
PanteraDoug, Where did you find a one piece oil pan gasket for a Cleveland? I have only found those for a Windsor? I have used those on my 302 and the do work great. Thanks, Evan
