Originally posted by ItalFord:
If it were me I would advance the timing regardless of what the marks say and see what the effect is. If if runs better your numbers on your balancer are off.
MSD distributors come with a kit of springs and bushings depending on the rate of advance you need. If the springs would have lost their tension the engine would advance too quickly and therefor should not be lazy. It would most likely detonate. In this case the engine sounds like its lazy indicating a retarded timing. Am I off base here.
What do you think Doug?
Well advance springs normally operate by limiting the rate of mechanical advance. If MSD does it in reverse thEN they may have re-invented the mechanical advance? The heavier or thicker the springs are, the more load is required to stretch them out. That's what the weights are there for.
These distributors normally are supplied with the lightest ones installed, instructions and two more sets of springs. Guess where those springs and instructions wind up?
The normal scenario would be as follows: the buyer takes the distributor out of the box and installs it. Sets the timing, and away he goes.
Then in 1500 miles or so the car starts acting weird.
Owner takes out the timing light and "wow, this is screwy, timing is 30 something?" Then resets to 16. Now drives it. No pep. Maybe even backfires?
What has happened is that he just took out 24 degrees of mechanical advance. Well not really, the springs stretched to the point of falling off the dowels is what caused it.
There are no distributors that do not work this way with advance weights and springs that I ever heard of? Some distributors are made for reliability. Ford for instance is. Aftermarket, well dependability? I don't know about that but billet glitz? Sure.
Don't worry though. MSD tech already asked me to buy another product and leave them the f... alone. I agreed. I use Ford ignition exclusively. Still waiting for the first failure. Acell ain't much to write home about either.
Actually this is not something that is exclusive to MSD or any one particular make. Any distributor that uses the weakest springs will eventually have issues with the advance. In all fairness, they are mostly limited to racing because of the fuel octane issue associated with an advance all in by 2,000 rpm with a high compression engine. At 8.0:1, you probably can get away with an advance that is all in by 2,000 rpm with just premium pump gas? You will not on even a 10:1 engine unless you run 106 leaded.
As far as playing with the distributor to see if it helps regardless of what the timing mark indicates, try it, but if it's the distributor mechanical advance, it won't mean anything but a waste of time and you will need to take care of that first.
George Pence here has been cautioning the balancer slipping issue for some time. It's been seen on other Ford engines too. I've heard of some 289 HP balancers being out of whack as well.
