Over the next few weeks months the hard part of putting it all back together again, wish me luck, and thinks for the likes....
quote:What are your cam specs? Be sure to check your Scorpion roller rockers for clearance to the pushrod. Doug Braun on the DT Mail List had an issue with contact between the pushrod and rocker body (links below) and I had the same issue with my new engine. Given that you're using a Windsor, it may not be an issue. I believe the angles are a bit more extreme on the Cleveland, but my Scorpion Race Series roller rockers were spec'd to be capable of .950" of lift, and my cam is only .588" at max lift.
Details:
http://poca.com/pipermail/deto...December/048101.html
http://poca.com/pipermail/deto...December/048138.html
quote:anyone know where everything goes? lol its been so long apart.
quote:Originally posted by JAG13CAT:
Looking good Detonator!
Question - I am in the early stages of restoration and was wondering what distributor (setup) you're using and if it will clear the bulhead?
