Tom
Wow,
What a day, it has been just over 1 month since we brought Dave Ward to fiberglass reproduction AMX/3 body and he is just flying. Lots of progress happening very quickly and the quality is superb. Dave has so much experience with the Big Red Camaro and other race cars that he is known for over engineering and building strength beyond what is required. Thank God, because if my butt ever rolls one of these fancy firecrackers I want to be in a Precision Welding chassis made by Dave Ward. Super strong! As you can see from todays images, the Wilwood pedals are in place, the front left wheel is bolted on and the front tires are 295 in width, on the rear they will be 345. Wow, those are some big meats! I love traction, it's loosing it that scares me, with tires this wide, the end of adhesion will be pretty far away. What can I say, I am not a chassis builder, so observing one of the best in the world in action, is a thrill. The front sway bar you may notice is not a C4, it is a NASCAR thing and you wouldn't understand, or maybe you would? Do I sound pompous and arrogant today? Well I am!
Tom
We may not run a power steering pump, because the front end is so light we might just connect a hose to each end of the fittings and loop it back into itself on the rack to let it keep a little fluid inside as a manual rack and pinion, we'll see. Tim Burton and I had lunch together today as well. I can't express enough how important his contribution is to this project. Tim is performing so many critical jobs to support Dave's work. Not to mention all the pictures he takes, thanks Tim. Thanks Dave. Thanks Richard Teague. Thanks investors.
Your fan,
Tom Dulaney
