The engine is now out of my Pantera and available for sale. The following information lists the engine parts. This is a complete and very dependable engine that has made over 20 trips to the Las Vegas Fun Rally and several to the Reno event. Long distance award in 2010 Reno event. CHI 2V aluminum heads and matching TFC 2V intake manifold were installed in 2007. Aprox. 8K miles on car since that installation. Current estimated horse power is about 400 with this head and cam set up. Bottom end was rebuilt at 48K miles and engine has an additional 40K miles since. Does not use oil, however it is a stock four bolt main .030 bore block.
Block: .030 over bore
Pistons: Flat top forged
Cam: Crower 555/550 lift 300/290 duration HYD
Heads: CHI 2V aluminum. New springs and Roller rockers. Chrome Moly push rods.
Intake: TFC 2V with one inch milled off of top.
Carb: Holly 650 double pumper
Dist: New Malory Unilite with added roll pin.
Balancer: Romac with timing chain and gear set installed with heads.
Water Pump: FlowKooler aluminum.
Oil Pump: Melling with high output modification.
Oil Pan: Kevko 10 quart road racing type.
Valve Covers: Ford Motorsports.
If there are any items that I have missed, please contact me directly. $3000.00 OBO. Engine is currently at Pantera Performance Center in Castle Rock Colorado. Buyer will be responsible for shipping costs.
