At my neighbor's advice I added a fuel system dryer, Isopropyl Alcohol, and the problem is solved, it runs great again. So, it was water in the tank.
On a second note, I used to run an electric fuel pump but changed to mechanical years ago. Beats me why, it was too long ago. If I let the car stand for more than two weeks it appears fuel starved and starts hard, so I pour a little gas in each Weber carb and it fires up immediately. An electric pump has been ordered and will be managed by the existing fuel pressure regulator.
The same "vent" holes in the top of the Webers that you have been pouring fuel in to prime them also will allow water in. (under the screens)
Once running 48ida's you need to take precautions to prevent that from happening, like no car washes, etc.
It isn't enough to just cover the stacks. You need to cover the carbs also.
Depending on what the blend is to your local gas, here in the North East, there is an addative to the mix at the refinery that when the car sits more then two weeks and the fuel in the bowls evaporates, tends to get sticky, dry on the Viton in the inlet valves and glue them closed.
When you disassemble a white sticky substance clearly shows on the inlet valves.
With Webers, it is an excellent idea to switch the inlet valves to the Gene Berg glass ball inlet valves. So far with them I have not had this issue, so it appears that it is a Viton valve thing.
My Holley carbs however continue to have the problem.
