All: Went out today to drive the car this morning. Up until today, there have been no issues with the car. Starts, charges, all normal. Battery is on a BatteryTender at all times when not driving. Last time car was driven was the day before. Car starts and warms up fine. I immediately notice once RPMs get about 2500, the ammeter is on full charge (+ 80 amp side of gauge). Note, I have a VDO ammeter that I installed many years ago in place of the original meter that Lance Nist had installed his shunt on years before. When the car is at idle RPMs, the ammeter is reading a slight charging + side like it normally does (BUT, seems higher than normal). When I apply load to the system - headlights, windows, you see a discharge on the meter as normal. My fans are wired directly off the battery and turned on, the ammeter does not respond. I drove the car for about 15 minutes - the ammeter continues to show full charge when at running RPMs and drops to a very low charge at idle.
What I have checked:
1. Primary lead wires to the ammeter - solidly connected and tight
2. Battery terminals - clean and tight. Battery disconnect switch tight.
3. With car not running, battery shows 12.6 - 12.7 volts. Car turns over fast as always and does it many times over and over. Battery water is topped off
4. With car running on fast idle, alternator shows charging voltage of around 13.6 volts, so system is charging.
5. Chassis ground is tight and clean.
What I have not checked:
1. The battery with a load tester
2. The terminals at the alternator
So, what do you think could be causing this?
1. The ammeter is bad and reading excessively now?
2. The battery is bad, but somehow continues to start the car?
Appreciate the electrical insight and help.
Lee
