SOLD WITH AN MSO ONLY
This is the Pantera GT5 Tube Chassis one piece composite steel reinforced hand-laid body painted white . This car has an OEM Detomaso Pantera transaxle, all four corners of suspension (yes mounted and rolling) front steering rack is OEM Pantera and OEM Pantera complete doors with glass and electric motors. Has seats door, panels center console, rear bulkhead panel , fenderwells for the rear , OEM fuel tank, Car has been painted white (not gel coat). Has Cragar SST wheelw with newaly new tires (less than 300 miles used on another test car pantera we used for shows).steering column is ford tilt, has adjustabale proportioing valve, OEM pantera shifter , shift gate and shifter rod on heim joint, OEM pantera pedal assy complete mounted, 351 engine (see picture on stand and no stand is NOT included) purchased engine from outside source claims it was rebuilt (no guarantee there) OEM used exhust, pantera mufflers extra set. Also has tailights door handles, Grille , A/C condensor with braided lines, 8ft+ battery cable, virtually all the parts to make this a car again .
The body was made by Chris at Sema Show Cars in Mesa Arizona out of Fiberglass.
Bought the chassis to simply swap over onto my 71 Pantera which was wrecked, after a body shop went through my car it turned out that i could have my cars chassis repaired so i no longer need this. I only had this for a few weeks, all the parts it came with are here for exception of the wings and the pre-L front bumpers & windshield that i need for for my own car.
PICTURE LINK BELOW HERE
https://picasaweb.google.com/S...owCars/WhitePantera#
Call me Julian 615-947-4985
I have it listed on ebay:
http://cgi.ebay.com/ebaymotors...em&item=250846316760
