chemical dip. total restoration
quote:Originally posted by dean:
it seem like they neutralize the car with a good pressure wash. then treat it with some kind of chemical that prevent surface rust. i'm sure there will be problem if it was taken out in the rain or water somehow got into the crevisis that i cant treat with por15 or some other kind of chemicals.
The reason i had it chemical dip instead of bead blast is the pantera rust from the inside out. there is no way to blast inside all the hidden areas and blasting will leave sand or bead or glass in the hidden areas forever.
dean
quote:Originally posted by LF - TP 2511:
I've heard cautions regarding dipping, in that the solution can tend to 'hide' deep in seams, only to come out later with bad results.
quote:it seem like they neutralize the car with a good pressure wash. then treat it with some kind of chemical that prevent surface rust.
