I'm beginning the process of restoring the front trunk on my '72 and need to know the proper way to remove the pedal assembly. It's unbolted and the clutch and brake masters are removed. this leaves the Alloy pedal support loose, but the pedal pivot rod is too wide to fit through the opening in the trunk wall. Tips?
