Somewhere around the inside edge of the lower support,  DeTomaso left a fingernail's worth of the edge off in the cast iron, sufficient to get a screwdriver in from the opposite side and knock out the bushing. The nick in the cast iron is always filled with grease- sometimes, hardened grease and difficult to see unless you know what to look for. On our '72L, I think it was on the bottom edge.
