I added some additional pictures.
The chrome work on this car was mostly done by Speed and Sport Chrome Plating in Houston. We used mirrored stainless on the firewall and fuel tank bulkhead. Most of the other custom covers such as the ones over the strut tower brace bolts and the oil pressure sender we custom made out of aluminum and then polished.
tajon, the middle tip is functional. The mufflers are actually one Magnaflow muffler that is cut in half with a new end and the tips welded on. If you look under the car, one says "Magna" and the other says "Flow."
If you want to see a ton of pictures of this restoration from start to finish, you can go to my website which is classiccollisionandrestoration.com. Go to the "Gallery" page and click on "72 Pantera."
