Went through a few old threads and saw some different configurations. Almost everyone mentioned going to a remote unit so that the pump drew directly from the radiator vs having to draw water further mounted on the engine. So the remote mount pumps require a block plate and some kind of thicker plate pieces that use the block plate holes to mount to and thread a 90 degree AN or pipe fitting to for the water inlet and outlet.
Those of you running these types of pumps, which brand are you using, what is their GPM rating and how long have they held up. If you can post Part # and Brand that would be great. Are these block plates just custom jobbers everyone has done? I know the main block plate can be had from meziere etc, but wasn't sure about the brackets used to tap the fittings with.
