yes ... I'm playing with the ignition on my car also. It seems when I connect the vac adv after putting the timing light on it and disconecting the vac hose ...when I reconnect it to idle speeds up ... I have about 9.5 in vac at stand still ... I would think the vac adv shouldnt adv the distr until acelleration . NO ?? its driving me crazy.
Ron
Thanks, I turned it clockwise just a smidgen and it is running better now. Is there any disadvantage of too much retard...loaded question. Some day I will get out the dusty garage sale timing light and try to figure the techinical way of doing it. But for now Ferrari's can see the rear of my car again, and hear the Thunda. Smiler
  • ORNG_UFO_Rear2
Turning the distributor clockwise advances the timing.
For optimum performance, you want as much timimg as possible while avoiding detonation/pinging..
Your telling me ...... LOL
No .. really its set at about 5 or 6 degrees initial and advances to aporx 30 at about 3500 rpm ... I rebuilt the carb and installed a 55 power valve and only idles when it warms up.
Have no vac leaks tested it ... do you think the vac adv diaphram has a leak and I'm loosing vac. it has 6.5 when warm and 9.5 when hot.
Didnt have enough time Sat to figure it out ..but I'm on it along with a thousand other things ..LOL
Ron
Ron
What cam, heads, intake manifold are you running? Your initial/total timing is off by about 10/8* assuming a conventional, moderate iron head motor. What happens when you advance the timing to 14/16* initial according to your balancer?
Assuming the indicated timing is correct, I think you need an additional 8* of timing, or use George's method of setting timing where you adjust the initial timing to produce the highest RPM, drive it, and back off a degree or 2 at a time until any detonation or pinging disappears. That should make a significant difference in idle quality and drivability. Good luck..
Its a 79 GTS 100% stock ...I THINK .. except for a Blue Thunder intake and a Holley 650 but I have to admit it idles a little wilder then stock maybe a cam was replaced but dont think so. It has Tri Y headers and stock exhaust Have not tried advancing it ... but I could try.
Ron, I dunno if it is true of your car or not but we both have euro spec GTS. Mine had compresion so high that I had to run premium and octane boost just to keep it from pinging. Maybe that is why you can only run 8 degrees instead of 16. I had mine at 16 and it ran like a stripped ass ape. BUt then again I had to boost octane.
Ron's motor originally had exhaust gas recirc, that means the compression ratio is 8.0:1. I normally twist the distributors on those motors for around 20 degrees initial advance and hook the vacuum advance canister straight to "ported" vacuum, no little vacuum signal control goodies in between. (the factory spec for that motor is 16 degres initial, so 20 degrees shouldn't give you any concern) I leave the vacuum retard side of the canister disconnected, always.
Even so, you should be able to operate the motor on 87 octane fuel. If the motor tends to "run on" or diesel with 87 you may need to switch to 89. Operating on the lower octane fuel will actually improve your fuel economy.
the cowboy from Hell
Yes, 38 degrees sounds about right to this old memory. the exact numbers are dependent upon the fuel & carb tuning, camshaft, etc. Been a long time since I had an 8.0:1 motor on a dyno. Mind you, I always stuffed a different cam in those motors, but nothing too radical.
Flat top pistons, zero decking the block & milling the heads can take the compression ratio into the 9.5:1 range with that motor. A slightly stouter hydraulic cam, better exhaust, big valves & porting for the heads, can get the motor into the 400 bhp range, even with the 4300D carb. The engine maintains excellent drivability.
In the seventies when I was doing this work, most big block equipped cars didn't have 400 bhp.
I had the run on problem but it was because my timing was set at bout zero. It ran too hot, but then I cranked her up to about thirty and that was just a tad too much so I think I have twenty or so right now. But I don't have a vacuum thingie on my distributer, it must be a chepie. It is a Mallory unilite. SO far it ain't been no trouble, but it must be inferior cause it doesn't have a vacuum advance.
The Mallory Unilite is available with or without vacuum advance. I just bought it with VA. Both are adjustable in terms of mechanical advance, rate of advance, and vacuum advance. I 'assumed' it came with the adjustment tool like they used to. Nope, had to order it seperately, just arrived today. Good luck.
George you maybe right with 8 to 1 and I know the motor has never been apart. But the car ran awfully nice with 100 octane cam 2 unleaded out of the pump and suprisingly too good at Pocono. Quick question what cylinder pressure should I get with 8 to 1 .. compression. You have me curiuos.
I'm sure your right though with the timing that 5 or 6 degrees that I have it set at is not enough. But another question ..I dont have any vacumn cansiter that I know of ?? maybe I have to check that too ... I sound like a RETARD but have not spent much time on this car .. I have been working on 6476. whats the proper set up for vacumn to the distributor .. from the fuel block on a holley to the distributor ?? No ?
Thanks
Ron,
Regarding compression readings: I don't remember what compression readings an 8.0:1 351C had, I don't think I ever had to take compression readings on a 351C.
Regarding the distributor: A vacuum line from ported vacuum to the advance canister is a starting point, and I know for sure it works just fine on a '73 - '74 vintage 351C 4V (Cobra Jet). Ported vacuum will be found at the nipple that sticks out of the side of the carb/metering block. The vacuum nipples on the carb base (throttle plate) are manifold vacuum.
Originally posted by johnk:
Nope. Perhaps on some engines, not ours.
Here's a good ignition tutorial covering the basics.
[URL=http://www.fordmuscle.com/archives/2000/03/timing/index.shtml[/URL]
Thanks for the info Johnk, nice reference website. I thought for sure rotating the distributor clockwise retarded the timing...this is why I stay away from engine work. Sometimes you begin with one simple question and it goes who knows where. That explains why it is slightly more difficult to start my car now, but it runs like a bat-out-a-hell. I may get up the nerve to scrunch back in the engine bay again and turn the distributor counterclockwise to retard the timing just a bit, but not back to where I was in the first place.
