Thats the contoured plate that covers the big hole in the inner rocker by the seat, and mounts the male seatbelt retractor. No choice but to use it. Unless your car has racing belts that don't retract.
To make sure that there will be no missunderstanding; It is the spacer that I do not remember if it should be fitted between the plate and the retractor or not. best Regards SF
