Just installed a new aftermarket clutch slave cylinder from Hall Pantera. I assume it's a longer throw, so how should it be adjusted? What's the difference between it and a stock unit? Also, it seems just a tad narrower than stock and is moving from side to side. It seems not to move fore and aft. Has anyone had a similar experience with this unit?
The replacement cylinders adjust exactly like a stock one; the difference is a slightly longer body with a smaller internal bore. So for the same distance of push on the pedal (and a timy bit more effort), the slave piston travels further, opening the clutch up a little more. If the cylinder is loose, thats a question for the vendor who sold you the thing. But if it was me. I'd remove the cylinder and smack the top of the steel mount slightly, to distort it & pinch the cylinder a little more & stop any rattles. Or, RTV or 'Liquid Nails" from the carpenters section of your hardware store, spread aroundthe cylinder/mount area would do the same without brutality....
I put my cylinder in a metal lathe and ran three bands of med. to course knurling around it. Then painted it with a permatex make a gasket to make it more solid. It works perfect. By the way you can buy new/better/thicker snap rings, for the cyl., at Orchard Supply Hardware. Marlin.
