It makes me wonder what will happen if you put a small spare on the rear, while on the other side you have a 335-35-17. The limet slip differetial gearset will have to slip one side a lot to keep the car from going in circles? That makes me belive in a tall skinny spare.But short enough to fit the front without scrubbing.
I don't know as I've never seen one pumped up.
The space saver stays deflated until you need it, otherwise you cannot get it in the front trunk.
But I guess it needs to be close or else the handling will be dreadful.
One last thought - if you use the spare, will the big wide GT5 wheel you have just taken off fit inside the car anywhere?
Hey guys,
I've never seen the space saver spare for a Pantera! Seems everybody tosses them out.
Some '69 through '73 Mustangs were equipped with space saver tires. The size was rated 7.75 x 14 and the tire was manufactured by B.F. Goodrich.
I have no idea if the Pantera spare was borrowed from the Mustang, if so, then replacements will be as near as the nearest Mustang restoration shop. However, I believe the space saver spare for Mustangs is a highly sought after item, so I'm not sure if they have ever been reproduced. If they haven't, then you won't find one for a Pantera either. By the way, a 30 year old tire is not a spare tire, please don't use it.
I carry a portable, 12 VDC air compressor & tire plugging kit in my front boot. Plus a set of pliers for removing whatever has perforated my tire.
