No I did not remove rack .I had a flexible cable with a chuck on the end hooked up to my drill and with a small drill bit drilled hole. Then used small self tapping screw .The rack already had a screw in it but I think that is to hold in the original bushing. I was told you leave the old one in and just add the brass one , The brass one was installed when my brother had car. Don't know way he did not put screw in there to hold brass bushing in . he passed away so there is no way to ask him .
