Finding a genuine Pantera Ferrero Wheel will be very very very difficult. Your best option is to seek out the similar model Ferrero Wheel used on other autos. It may not have the proper lettering as found on the Pantera version, though.6A8F4B30-AA83-45AB-940F-DD40B3A33410
finding the correct Ghia  horn button will be more difficult than finding the steering wheel. I don’t believe I have ever seen a correct one offered for sale. I was able to locate an acceptable Ghia emblem and adapted it to a generic horn button for a close but not OEM correct look.
this is a correct OEM horn button
25A8DE0A-806C-4253-B7EE-E81632CCC913
this is my creation 😕😕
A379AABE-A520-4EDC-B9BC-2C65BB2FB646
locating a hub will be a little bit easier if you can find a hub designed for our capri column. They are not very common. For some reason the Ferrero Wheel uses a 75 mm PCD bolt pattern. The closest you will be able to find will be 74 mm PCD. I found if you oversize the six mounting holes of the wheel, an acceptable mating can be accomplished.
this is currently on eBay italy
9D5BF61C-589C-440C-B018-0B9A377094F4
Images (4)
  • 25A8DE0A-806C-4253-B7EE-E81632CCC913
  • 6A8F4B30-AA83-45AB-940F-DD40B3A33410
  • A379AABE-A520-4EDC-B9BC-2C65BB2FB646
  • 9D5BF61C-589C-440C-B018-0B9A377094F4
David,
your photo failed to display
I have never seen any adapter offered with the Ferrero 75 mm PCD.
The two spoke I purchased from Europe many years ago was still mounted to the Lancia OEM hub.
as Dennis Q had adapted a Grant removable security key-locked hub to  2511 for the LeCarra Wheel, I wanted the two spoke to be interchangeable with the LeCarra.
The grant security lock is designed for their proprietary three bolt PCD wheels, so I purchased a second security lock (just to obtain the removable wheel-attached portion) and the appropriate three hole to six hole 74 mm PCD adapter.
The conversion done by Dennis used a no-longer-made capri three hole hub adapter made years ago by Grant, so signal canceling is not an issue with this assembly.
5395C776-9FB4-4A80-824C-F18EDE5B4B2F
  • 5395C776-9FB4-4A80-824C-F18EDE5B4B2F
I recently replaced my stock steering wheel. I wanted a Nardi but I discovered that the mounting hole pattern was larger than a Momo (74mm vs. 70mm). I found a hub adapter that was drilled and tapped for both, but I really wanted a Detomaso center emblem. Ron McCall offers a really nice center cap but it's drilled to fit a Momo wheel. I searched ebay for Nardi horn buttons and luckily found one with a Detomaso logo from a guy in Germany. The wheel I bought is smaller than stock (330mm) so I gained a little leg room in the process.
  • DSC03787
