I see the vendors all seem to have their own take on a chassis stiffening kit. I am just wondering what people here are using and if you can suggest which kit is best.
Thanks,
Wade
quote:probably the most popular and I think are a bolt in (don't you have to weld them together
quote:Some are more valuable to the chassis then others but none are really "needed".
quote:Originally posted by 4NHOTROD:quote:Some are more valuable to the chassis then others but none are really "needed".
IMHO, chassis stiffening is absolutely required with high horsepower and fat tires.
That is the first time ever that I've heard that chassis stiffening is not needed.
No experiment needed to determine why you got cracks. Your car is clearly flexing or else your paint would not crack.
I read posts where a member was driving behind a Pantera and could see the side gaps of the rear decklid clearly changing as the car went around corners. No more movement after the owner stiffened the chassis.
Just my 2 cents.
Will
quote:To me they are just glitzy techno jewelery
quote:Originally posted by accobra:
......... and we agree a basically simple 6 point roll cage is the best solution ?
