There may be a small amount of interference in the angles between bar ends and the a-arm brackets, making it difficult to attach all the bolts. In that case, you might need to jackstand the frame and use a floorjack under each a-arm to get the angles correct so the bolts go in unstressed. I find adding a spot of oil to the a-arm attach bolts helpful. Many Pantera body/chassis are twisted a bit- especially those with big wheels and stock bay-braces, making the angle-matching with swaybars even more problematic.
I just removed the front and rear sway bars (I call them anti-roll bars). I have done it before a few times as well.
Easy to remove with the car up on jackstands. I did not use floor jacks under the suspension - Not required. I remove the outer clamps first.
INSTALLING the anti-roll bars is different.
As stated above:
1) Put the car on jackstands
2) With a floor jack under the suspension, jack up and install the a-arm bushings and clamps so that they go in with a minor amount of coaxing. Oiling the studs and bolts is a good idea (Thanks Bosswrench) - Although I do not know the effect on the lock nuts (inner clamps). I install the outer clamps first. Then push in (rear), or down (front) on the anti-roll bar and attach the inner clamps.
3) As David said. Tighten up after you get all the fasteners started.
