This is for the Pantera project that I received in February. The engine and ZF are getting close to installing into the engine bay. Since the engine and ZF are still on the ground I would like to test the clutch and hydraulics, and decided to fabricate an extension to the braided clutch flex line. It is a section of 1/4" nickel copper brake line with flared AN fittings and a AN coupler. I will be trying it shortly. Has anyone done this type of test? If so, any tips?
The Centerforce clutch disk, pressure plate, and aluminum flywheel are all new. If there is a problem it will be better to find out now while the drivetrain is out of the car. Fixing any hydraulic issues will be easier as well.
