Team, well not so easy to cover all angles for a Motor rebuild. Pistons 4.020 bore) got sorted, Oil system modification/restrictors got sorted. Machine shop set up..
Aim to set up a good pulling street engine with max say 5800 rpm OCCASIONALLY for German Autobahn
However...
1)will go for new Trick Flow Heads 62 cc kind
2) Cam shaft will be Crane (as we discussed in the other thread) with Advertised (Theoretical) Valve Lift = 0.586”/0.609”
Rocker issue
I did NOT Realize that FULL ROLLER ROCKERS might need more Vale Cover clearance....Can anyone please help? See picture. Fall back would be Roller TIP only but worst case only..as I want to keep the Covers...
TX Matt From Germany
1)
