hey Jedi
thanks for the reply...
the mounting bracket does have an extra piece on it but is easily removed .. two extra mounting holes were made to attach this bracket but are not visible once tanks are installed.. that is the only mods on the mounting bracket .. the over flow tank on the other hand .. has been modified considerably .. i couldn't remember what i did to them at the time of my first post but now i remember that we started with a over flow tank (which is bigger than the pressure tank) and added a 1' NPT bung on the bottom of it .. also we shortened the tank about 3 inches.
i have access to quality machine and welding work so if you want me to alter these tanks, i'd be happy to do that ..
the only thing i can do to make them like new (precision pro-formance specs) would be to make a pressure tank. i could also make a shortened overflow to your specs ..
sorry for the confusion ..i'll post another pic to the web album
willis
i will ship them anywhere.. for 1/2 the shipping cost ..
they bottles were altered to fit my boat .. i can put them back to original except for the length of the bottle .. the brackets are altered only with two additional mounting holes .. that are not visible once installed .. but could be filled if necessary
