I just purchased a 1972 pre-L Pantera. There appears to be some toe-out on the right front wheel. The local alignment shops don't have the specs. Would someone send me the wheel alignment specs or tell me where I can get them. Thanks.
Also, where do you get key blanks for the Pantera? I need to get an extra set of ignition and trunk keys made. None of the hardware stores have the blanks.
Unless you're going to autocross the car, the following will work just fine at the front:
Caster: all you can get by moving the shims.
Camber: in at the top by 1 to 1-1/2 degrees
Toe: in 1/8 for 7" wheels, in 1/16 for 8" wheels (Some cars run 8" Campys at both ends)
At the rear, set toe to 1/8" in for any wheels & tires. But before you do this, check your steering rack- the stock bushing on the passenger side tends to wear rapidly, producing sloppy steering that may look like a toe change.
