In the book I got with my car, it is a drawing of where to drain oil from the transaxle, where to look for the right level, and where to fill new oil in. BUT, the bolt that is shown in the draving that shows where to fill in oil is not to be seen on mine..... Where do I fill oil on mine?
  • DSC06195-3
That location is your fill hole, also.
Get it up to there so it just covers the bottom threads.
An internal passage between ZF sections has a very small size, so let the oil settle for a bit, and then check to see if more is needed. Good idea to then check it after a bit of driving, also.
Your ZF should have a black tag on the driver's side. It will note what model ZF it is.
Last # in this photo is a 2, thus dash 2 model.
  • Picture_6
