I upgraded my 72 AC system with Quella's kit a few months ago. Here is a basic diagram that was in the kit.
That is great information!!!
thinking 🤔……..
LeMans850, check the length of that thumbscrew holding your hinged fuse box door closed. Decades ago, one member found the hard way that if a too-long thumbscrew or too much tightness is used, the screw end barely clears the fuse box assembly. Depending on hand tightness or warping of a stock door, the slightest body flex or foot pressure from a passenger can short one of the hot fuse terminals through the door to ground! I published a warning note in the POCA Newsletter at that time.
Some cars arrive at shops with unexplained burn marks in the plastic fuse holder! Cause is not obvious when the door is open since the thumbscrew moves with the door. The fix is to shorten the thumbscrew enough that it has only 3-4 threads engaged and very little protrudes near the fuse box. The screw is not structural so you don't need many threads or much tightness. I made a short standoff for my stock thumbscrew, which also allows a better hold on the thumbscrew head that otherwise sinks into the carpeting a varying amount.
Will do!! Especially if all the electrical work done! Great tip!!
Thank you
I spoke to earlier… I added some electrical… Shouldn’t but I did
that interior is starting to grow on me each time I see it.
@LeMans850i posted:It’s just exhausting to trace ALL the little stupid things… just a sampling:
the spring holding the backup light bulb touching the center lead of the socket!
wire for the brake light cut in the harness footwell/“firewall corner and then nicely taped the harness
headlight relay minor corrosion on one contact (passed 5V)
Original AND New headlight switch faulty
hazard switch incorrect connected
head light switch incorrect connected
Center console instrument lighting incorrect connected
A/c switch partial no contact
door interior lights switches not connected, no wires
turn signal stock switches corroded
and so on and on….
Now all the things you just read are the solutions to a problem or the problem itself but I get
fuse # 4 blows sometimes and right side rear lights not working and no brake lights at all and hazard when turned on stuck in on and light switch pink wire is getting warm and no horn and lights only open
all that in one go….!!! And I ask myself: where is the problem… and that is where I went wrong 😑 the question I should have asked myself should have been - how many problems are there‼️
That’s a lot of neglect and / or neanderthal electricians at work for a long time on one car! I’m having lunch with my multimeter and a 10 foot wire..
all the wiring I did for my additional stuff is not hooked up … just run the wires but not connected to power:
Powersteering, electric fuel pump, second headlights, Fuel pressure gauge, ignition switch, starter switch, interior fan, heater hose valve,voltmeter , clock… all that will get there own fuse / relay panel!
when I’m done with this car I know pretty much every nut, bolt , bushing , cable, wire, bulb, connector, hose, tube, hydraulic cylinder, bearing, ball joint, spacer and so on by their first name!! I touched them all!🖕
This was me 9 month ago…
…read the last paragraph…
YES… I know them all by their first name and what they like for breakfast…
what a crazy Journey it is….
Big WOW
AND thank you to everyone here and at PIM.
From my little model sitting in the grass at the SoCal Pantera meeting
to this and everything working …
but we all know… there is always something to do and I guess I go back to work….
