Finished the half shafts, spreader bar and A/C fan shroud.
This works was completed last week, before the battery in my camera died.
Another from last week.
Radiator area cleaned up.
Repaired radiator. Thanks to Larry, found a place local that did all the work for less than $225.00
Most of this weekend was the detail work around the ZF and engine.
A/C shroud.
ZF and shift linkage.
Spark plug wire loom kit to be installed after my valve covers are done.
Thankfully there is only a few things left to do on the "Have to Do" list. Then I'll be out running and helping Larry on his next project.
Got a few more items off the list this weekend. Still waiting for the last parts to come back from powder coating. If everything falls in line, may have her fired up next weekend!
Radiator repaired and re-installed.
Water tubes cleaned up and hoses replaced.
New stainless vent tube for the ZF installed.
New clutch slave line against original line.
New line installed. Slave going on next weekend after re-build.
Cleaned up the starter and re-installed.
Half shafts re-built and installed.
Last one this weekend. Hope to finish up next weekend!
Powder coating is finished!
Overflow Tank.
Overflow Tank.
Swirl Tank.
Exhaust done with High Temp coating.
