Just happened to be scrolling through some of your pics and i seen my car or what use to be my car thpnsvo9053. I enjoyed that car for a good 12 years before it was wrecked. Any questions about car let me know will be happy to answer! Stroker
Kjeld this is the coolest project ever! Remember to post lot of pictures ! cant wait to see it get finished. Soooo nice
Hi Stroker.
P.M. Send.
Kjeld
P.M. Send.
Kjeld
Hi kim.
Thanks.
I wil.
Kjeld.
Thanks.
I wil.
Kjeld.
quote:Originally posted by kim k:
Kjeld this is the coolest project ever! Remember to post lot of pictures ! cant wait to see it get finished. Soooo nice![]()
I just had a quick look and its sold... maybe Kjeld did buy it
The work on the other car you're doing is amazing...
quote:http://www.gullwingmotorcars.c...-pantera-c-1854.htm?
Starting to build the new design.
the metal angel iron/wiere and the paper is just to get an idear hav it will be.
kjeld
kjeld
kjeld
quote:Originally posted by Kjeld Pedersen:quote:Originally posted by Kjeld Pedersen:
kjeld
quote:Originally posted by Kjeld Pedersen:quote:Originally posted by Kjeld Pedersen:quote:Originally posted by Kjeld Pedersen:
kjeld
quote:Originally posted by Kjeld Pedersen:quote:Originally posted by Kjeld Pedersen:quote:Originally posted by Kjeld Pedersen:quote:Originally posted by Kjeld Pedersen:
kjeld
quote:Originally posted by Kjeld Pedersen:quote:Originally posted by Kjeld Pedersen:quote:Originally posted by Kjeld Pedersen:quote:Originally posted by Kjeld Pedersen:quote:Originally posted by Kjeld Pedersen:
kjeld
Wow,that's ambitious. This is a positive consequence of rising values. More Pantera's are revived from the dead. I salute your courage and commitment.
Thanks JT.
I find a almost new Coyote engine (2016 only 2744 miles).
It will be connected with a 6 speed Porsche gearbox.
Kjeld
Kjeld
Awesome project. Can't wait to see the result.
Trying to get some rear lights to fit in!
kjeld
kjeld
kjeldquote:Originally posted by Camo:
I always found making something on one side not too hard but replicating the work in a mirror on the other side a challenge.
Partly because it needs to replicate the other side but also making the second is kind of anti-climatic.
I always have the energy and enthusiasm for the first side but gennerally have to motivate myself to do it again.
Thats amazing. Cant wait to see it done
What are those taillights from? They look good
They are 2017 model Audi R8.
I just turn Them around, using left for Right side and tip the Angel/position.
Kjeld
Kjeld
some "small" brake for the project.
kjeld
kjeld
kjeld
Looks good. Wonder when they produce a full 180 degrees ;-)
mabye this one is easere to see.
i think around 110 degrees.
Kjeld.
The brakes are on in one side.
just for testing.
standard size in front.
kjeld
just for testing.
kjeld
just for testing.
new size in front. 400mm x 34mm 8piston
kjeld
just for testing.
kjeld
just for testing.
new size in rear. 360mm x 34mm 4pisten
Electric handbrake.
kjeld
just for testing.
Electric handbrake.
kjeld
just for testing.
Electric handbrake.
kjeld
[QUOTE]Originally posted by Kjeld Pedersen:
just for testing.
Electric handbrake.
kjeld
just for testing.
Electric handbrake.
kjeld
Regarding the position of the caliber in rear.
Can someone tell me if it will it make any change or not. If the caliber is in front of the rear axel or behind, i can change the position of the caliber and the Electric handbrake.
kjeld
kjeld
As long as the bleed ports are on the top it shouldn't matter.
Are all the pistons in the caliper same size?
-Sami
-Sami
This set have bleed ports in top and buttom, so it is possible to turn them.
Hi Sami.
The front.8 piston. 4x25,4mm and 4x34,6mm. there are 4 brake pads for each caliber.
The back. 4 piston. 2x38mm and 2x41mm.
this one only 2 brake pads each caliber.
kjeld
kjeld
-Sami
If there are bleed screws at both ends then it shouldnt matter. But since there are different piston sizes ther should be right and left caliper, don't mix the sides. But I guess you already knew that
-Sami
-Sami
Looks like good progress on the chassis too. Well done - almost ready!! :-)
only missing the outer sheet metal.
Coyote engine almost there.
Have to find another oilpan so i can get it longer back and more Down.
Kjeld
Kjeld
another one
one more
one more
Sign In To Reply
