I will be introducing an easy bolt-in peddle extension kit soon. It will extend the peddle assembly 1 1/2 to 1 5/8 inch 38 to 41mm which is the max you can go and still get full peddle travel without modifying the car's front firewall. Also I'll be offering several master cylinder reservoir replacement options for additional hood clearance that will fit the stock, Ford or GM replacement parts being used. The kit will contain the spacer assembly, all of the mounting hardware and detailed instructions to assist with break line mods or changes stock or aftermarket master cylinders.
Here are some pictures of the first part install.
If you are interested, please drop me a note.
Thank you.
Kirk
