Have any of you had good results with installing an electric fuel pump in the stock fuel tank?
Jack Deryke (Bosswrench) has done this. Haven't seen him post in a while.
Hmmmm🧐🧐
Electric fuel pumps, just like mechanical fuel pumps, are known to fail.
Dropping a fuel tank in a Pantera involves removing the engine and transaxle.
So if you proceed in this direction I would think you would want your fuel pump installation to be done in a manner that allows pump replacement with the fuel tank remaining in position.
My 2¢.
This will help:
I am working on this issue now - anticipating the install of EFI in the near future. I'll let you know what I come up with.
Thanks to all for replying.
I'll be using the mechanical fuel pump to fill a surge tank and from there the electric fuel pump for the EFI.
