Also installed the EIS (Engine Igintion System) from Pantera Electronics. So far, works like a charm, car starts right up, no hesitation or second tries. Lots of great features on this system. Check it out EIS
kirkevansAmeriSport GT5-S builder Pantera Parts Vendor
Is that one of the 2 sets of SACC CVs I sent Nils? They look well built. Dash came out great.
Just an FYI--I make a gauge insert with a separate Stainless trim. The center can be covered in a material of your choice. This one is finished in gray carbon.
Thanks Kirk. The CVs were installed in 2014, I got them directly from Scott. That gauge panel looks great, the original one does feel a bit flimsy. I´ll think about it
When you block a person, they can no longer invite you to a private message or post to your profile wall. Replies and comments they make will be collapsed/hidden by default. Finally, you'll never receive email notifications about content they create or likes they designate for your content.
Note: if you proceed, you will no longer be following .
