Hello i just purchased this 74 pantera from the original owner bought brand new.it in good shape. dispite sitting many years,Compression good has factory original duel point dist. Motorcraft Carb rebuilt, good spark but no go.it does attempt to start, Im curious with a devise in front trunk area called interlock over ride.does anybody have any information on this item.
thanks for all information. not trying to remove anything just information on the override thanks very help full, all fluids were replaced before attempted start, new plugs all new points,did not change cap and rotor by eye and looks wires and cap look good, this car was totally untouched time capsule.trying keep it as original as possible however the motorcraft carb may be the culprit even though it has been rebuilt,i am mechanically inclined and know panteras also  i have a 73 pantera with a boss 351 owned 13 years.this 74 seams a bit different,thank again for the wireing diagram for the lock out.
