100% of the Pantera parts vendors (including PI Motorsports, that hosts this page) sell stock neoprene or aftermarket urethane bushings as a kit. Adding asymmetric-flange urethane bushings to the front end is a cheap way of gaining 1 extra degree of caster for better high speed handling, basically free. Removing the old bushings approaches an engine swap in terms of sheer miserable labor. The stock bushings have crimped-on washers that are larger than the a-arm holes, so you can't use a press until one of the end-washers are cut or knocked off. Even then, it is absurdly easy to bend or distort the mild-steel a-arms with a press while pushing the old steel-jacketed rubber ones out. And there are 16 of them to change... Fred Terry wrote a comprehensive article on this job in the POCA newsletter (April 2000- 'Bushing Pushing')
