Has resulted after 7 months (I work slowly) of long overdue maintenance and updates to 4744, including oil/filter change, drain/change ZF lube, replace rr axle, bearings, and spacer, re-built front/rear calipers (installed Speed Bleeders) new pads,(cut the original front pad umbilical wires) ss brake lines, all new front wheel bearings, and re-rigging those PITA e-brake cables......(I still don't know if I have them correct!)
  • 1
Many thanks to Mike Drew for his prompting/prodding/encouraging/helping to get it on the road again, and to Chuck Melton and Lori Albino for their Super Bowl Sunday interruption to replace my rr axle, bearings, and spacer, and many thanks to Julian Kift for those donor front calipers and pads, which are working great.
  • 2
