I purchased a Halls aftermarket fan unit but have yet to install it as it was a multispeed unit as the dash switch wiring on the new fan unit was different to the original. I believe there are past posts on this site on how to resolve this speed interface wiring issue but just be aware a replacement unit  will not be a simple plug and play.
I have persisted with the original in my car but at best it does sound like a bucket of bolts in a tumble drier ......!
Just turn the engine on and problem solved !
Can not comment on the heater and Evap core item.
The OEM blower motor was a two speed unit but the new replacement motors are three speed units. The most seamless way to handle the update is to use a Pantera Electronics Console Switch Controller. It is designed to work with the new three speed motors.
Also, the logic behind the aftermarket heater core / evaporator is, the evaporator is 50% larger than OEM and the heater core is 50% smaller, all in the interest of helping the A/C work better. I can't tell you how effective it is though. Perhaps someone that has one in their Pantera will chime in.
