behind the pass seat oval hole thru the hole along the bulk head wall then make a right but go on the drivers side of the ebrake, thru the tunnel out on the pass side then i made a nice gentle bend to the unit. I have my system still stock and get 30 degrees when its 90 out
I am looking at doing the front location for the condensor. I was wondering what size condensor is needed, the other parts required and mounting brackets. It would be nice if someone had a kit available. I have the aluminum rad from Pantera Performance. Any help is appreciated.
