On my black 5S, I lost cold air when running the AC and trying to figure if it is electrical or not and maybe the compressor isn't getting juice. The standard Pantera manual says relays should be on the left side of the car by the door, but of course no panel is on the left side to open since my car has been modified, and looking around under the dash I have not found any relays yet. But reading the manual, it also says fuse 7 operates the AC compressor, and this fuse looks ok just by appearance. The fan runs well, but within 2 weeks I lost all cool air. When turning the switch for to operate the AC, I don't really hear anything (such as a little load on the engine, or any dash volt meter change). This is why I figure it may be electrical rather than AC coolant.
Would appreciate any ideas on procedures to check the fuse, or the switch. I can't find any relay yet, so can't check that even if I wanted to. The following are some photos. On this one, it shows blue fuse in the # 7 fuse. As I mentioned this fuse looks good, but not sure how to check it. I also looked at all fuses in case something was switched around and they all look good on appearance.
  • FuseBox
Originally posted by jb1490:
Jan,
Relays are located above the passenger's foot well, behind a large black metal cover. It is held in place with one wing nut in the center.
John
Thanks John, I saw that box too (below), but can't quite get into it yet in the cramped garage, and we have some rain going on at the moment so I can't get it outside. Frowner I only know of very few women who are flexible enough to get on their back into that position in confined space, so I will wait on that box untill I can drive it outside. But how to check the fuse to see if that area is working?
  • RelayBox
Thanks for the tips. But when turing key on, the FI is so loud that it is hard to hear back there when I turn the AC switch on. If I check at the fuse with volt meeter like mentioned previousely above, should I be checking with engine running, and/or checking when turning on & off the AC? I am just trying to somehow determine if it may be the relay without getting into that relay box. Thanks.
Jan, you have to start with the basics, and verify if the compressor is turning when you engage the system. This is a visual check by removing the bulkhead cover or observing the front of the compressor from some other vantage point.
The belt will always be turning the pulley regardless of how the system is performing, what you are looking for is the front compressor plate / clutch. If the clutch is stationary, then something has disabled the system. If the clutch is turning, then you have probably lost refrigerant or the condenser fan is not turning.
If the clutch is not turning, then you might have also lost refrigerant and the low pressure switch prevents the compressor from engaging. From here, you need a pressure test of the system.
The most likely diagnosis is you have lost refrigerant from a leak.
Checked the AC fuse with volt meter and test light and it has juice, plus I tried the horn to wake the neighbors and the horn works too (which mentioned above, operates from that fuse too). Also, was able to shut it down and keep the key on so that I don't hear the loud FI system, and I turned on and off the AC knob but did not hear any click in the engine bay. I tried the same technique on my group 4 just to see if I would hear anything back there, and when doing it in that car I could definately hear a loud click in the engine bay when truning the AC switch. So, maybe the relay to check next by replacing it? I suppose when I open that relay/wire box I will see all kinds of relays, so maybe just guess which one? I decided to check all the fuses on the fuse panel too, and not all of them light up with the test light (not sure if they are supposed to or not, or maybe just when using that item for the fuse). Did not want to get into the bulkhead if I don't need to for a visual. I don't think it is the refergerant because I had such cold air just a couple weeks ago, and now suddently just warm air.
Jan,
Only fuses 7, 8, & 9 will be hot without the key on and without any switches on.
Check fuse #10 (key on). If that checks good, check for voltage on the brown wire at the A/C switch (key on). If that checks good, then turn on the A/C switch and check for power at the white/black wire on the back of the A/C switch.
Does the condenser fan run when the A/C switch is turned on (key on)?
If you have to get into the relays, the compressor clutch relay should have yellow/black and green wires (plus two other wires). The condenser fan relay should have red and light blue/black wires (plus two other wires).
John
Jan,
John
Thanks John. I am not home now, but will check next week. When checking that brown wire and then white wire on the AC switch, should I just pull back on the connnection of those wires just enough to touch the meter test prong at those prongs with wires still connnected? I assume when doing so, the other prong of the meter goes to ground. Thanks.
Yes, keep the wires connected to the switch.
Yes, the other meter probe goes to ground.
John
Jan,
John
# 10 fuse lights up with test light. Then I checked the brown wire at the switch with a test light, car running and AC off, and no juice on the test light. Then tested the white wire same way but with AC on and no juice on the test light. Tested the test light too, and I know that works Smiler. What do you think all that means? Maybe go after the relay next?
The brown wire comes directly from the fuse panel. You may have a bad connection there. Does the heater/AC blower motor run? It is fed from fuse #10 via a second brown wire.
John
Yes, the air blows but just not cold. I will look again tomorrow closer at the fuse box for a brown wire, but I don't see it in the photo I took (number 10 fuse is the blue one on the left of the photo). Checking my photo on page one, I do see a brown wire way back there. What if I attached a aligator clip to a wire and placed it on the prong on fuse 10, and the other end of the wire had a female clip and placed it where the brown wire is on the switch and then see if the AC works? Would that be a way to at least test it?
  • IMG_3574LoRes
Yes, try that.
John
Yep, connecting as described through a seperate wire from AC switch to #10 fuse prong, I could hear the compressor click in the engine compartment. There was a wire at a second level down under that #10 fuse, but was grey. Now what do you think? Not knowing about electrics maybe I need to get into that relay box under the glove box? Maybe that grey wire from fuse 10 connects to the brown wire at the relay or something?
Jan,
The gray wire should be on fuse #11. Fuse #10 should have one red/black, and two brown wires. One of those brown wires goes to the AC switch, and the other brown wire goes to the blower switch. This is on original (unmolested) wiring. There are three terminals (male spade) connected to fuse #10. They are all stacked one above the other.
John
Dave2811's gave good advice. Unlikely that it is the relay. The relays are on a drop down panel secured with two wing nuts, so you don't have to damage your girlfriends back! I noticed that your fuses are incorrect and show alot of corrosion. This is not relevant to your current problem but I suggest you pull the fuse panel and thoroughly clean all your connections thereby avoiding electrical gremlins. Mike
Jan,
John
Its just odd that things worked before, as I have not switched any wires around. Actually looking again, that grey wire looks like some extra external casing around the wire, and the actual wire on #10 down under seems to be a real dark brown color (not the lighter brown color like on the AC switch). I will take another look next weekend and see how to remove that fuse panel, as I can't see squat behind those front wires to see what is down under.
Regarding that brown wire that comes out of the AC switch, it seems to travel up in the area of that relay box under the dash, which is why I was thinking maybe relay issue. Is that brown AC switch wire supposed to be coming directly from the fuse box #10 to the AC switch? If it is, I suppose it may be traveling up under the dash but I just can't see it.
Yes. You won't really be able to trace it, as it is buried in the wire loom.
John
If I take that fuse panel off then probably I could see things better, and/or screw other things up even worse by monkeying with it. Now I have back problems from last weekend messing with it. Next time I go to my mechanic I will be sure to tip him well, as tight work like this sure aint fun; except maybe for contortionists or those under 50.
Why do we not think it is the relay causing the issue?
Because the AC switch activates the relay coil, and there is no power to the AC switch.
John
Very good, thanks. Once I find a contortonist, will need to dive back into the fuse box area and see how to remove that fuse box and take a look see. Maybe that brown wire is burried behind there like you say, and got disconnected from doin 0 - 60 with lamboners.
Does this mean that I should drive 60 miles for a house call ??? Big Grin
John
Ha ha, yeah, or hire a true masochist who loves to experience pain in tight places. My lower back tightened up, so now need to fix that first, then back to the fuse box when I am better. If I get that fuse box off and find the brown wire still connected behind there, I would suspect that something odd happened with that wire itself from the fuse box to the switch. So couldn't I then just bypass that brown wire all together and make my own wire from the fuse box prong directly to the AC swithch (if it is really a direct line between both and nothing inbetween)? No way I can trace that brown wire all the way because goes up under the dash somewhere.
Correct. The brown wire goes from the fuse panel directly to the A/C switch, unless a previous owner did something to it. The wire connection at the fuse panel could be corroded. Another possibility is that someone may have moved that brown wire to another fuse.
So couldn't I then just bypass that brown wire all together and make my own wire from the fuse box prong directly to the AC switch
Yes.
It's buried in the wire loom. You would have to cut the black tape wrapping and hurt yourself again. Big Grin
John
John
Ha ha, yeah you know me well! Just cuttin tape under there would cause major injuries. Last question before I go to HomeDepot after I can walk and drive again: What size wire do you think goes with that switch/fuse connection? It seems a little beefier than some of the other wires. I could cut it and take it in, but not sure if I need to cut that wire yet.
Had to postpone looking at the fuse box since I hurt my lower back even further doing xmas lights on the roof like Christmas Vacation. Anyway, I got the fuse box out, and found three wires related to that AC fuse. In the photo it is shown by brown, white and black wire. The brown wire goes to the AC switch and hooks to a white wire by the fuse box, and who knows where that white wire goes. Then there is the black wire that goes to the fuse box terminal. From the photo it looks like that black wire is going into the thick red wire, but it isn't, as the black wire is just sitting in front of it on another prong Initially thought I found the problem because that black wire was connected somewhat loose. So I made sure it was on tight and put everything back in place, "then" tried the AC and it still didn't work. Maybe I should have disconnected that black wire from the fuse box prong and tested it for juice with ignition switch on? Or should I test the prong that the black wire hooks to on the fuse box? Ugh.
  • IMG_3820ACbrownWhiteBlackWire
I think as John had mentioned, it looks like someone has added some wires, the grey sleeved cable with the white and black wires. These most likely go to a a/c pressure switch. Have a look at Mike Dailey's excellent write up and this might be those extra wires. PanteraPlace
If this is what you have you can temporarily connect the 2 wires together at the pressure switch. Do not run it for long like this, it most likely means you are low on ac refridgerent.
Jan,
It appears that the gray cable (with the black and white wires) has been added. As bdud posted, it probably goes to an A/C pressure switch. That switch is usually located on the receiver/drier or in the refrigerant line adjacent to the compressor. Find the pressure switch and connect the two wires together (as bdud posted). Turn on the key and the A/C switch (with the engine not running). If the system now electrically turns on, then either the the system is low on freon, or the pressure switch is bad.
John
I found the dryer up in front of the left front tire, and see two blue wires going to it. There is also a sight glass on the top, but can't see it at all due to the location and would have to remove the wheel, run the car, etc. Funny, now the wires are blue on that switch, changing from inside the car. Just happens my back is still screwed up, so I may just do without AC. I never use it anyway being in heaven weather year round, but just thought it was a good idea to fix it anyway to keep the compressor running. After hearing everyone here, I now think it may be low on freon if that switch turns things off with low pressure. Plus if it needs freon I would suppose a team of 10 inspectors in white overhalls would need to be called the way things are with AC these days.
  • ACDryer
