On my black 5S, I lost cold air when running the AC and trying to figure if it is electrical or not and maybe the compressor isn't getting juice. The standard Pantera manual says relays should be on the left side of the car by the door, but of course no panel is on the left side to open since my car has been modified, and looking around under the dash I have not found any relays yet. But reading the manual, it also says fuse 7 operates the AC compressor, and this fuse looks ok just by appearance. The fan runs well, but within 2 weeks I lost all cool air. When turning the switch for to operate the AC, I don't really hear anything (such as a little load on the engine, or any dash volt meter change). This is why I figure it may be electrical rather than AC coolant.
Would appreciate any ideas on procedures to check the fuse, or the switch. I can't find any relay yet, so can't check that even if I wanted to. The following are some photos. On this one, it shows blue fuse in the # 7 fuse. As I mentioned this fuse looks good, but not sure how to check it. I also looked at all fuses in case something was switched around and they all look good on appearance.
