the way I did mine on the weekend was remove the top breather hose, get a small funnel and a piece of vacuum line, the vac line fits tightly over the breather tube and around the bottom of the funnel.
then pull the side plug out and slowly fill the funnel, it goes in the box and eventually it will come out the sideand you can plug it without spilling a drop !!
worked for me !!
