The books says:
"Wiggle the rocker arm and rotate the pushrod to check for slack, and look at the lifter to see if its plunger has moved. Run the bolt down while keeping track of the number of turns. When the fulcrum bottoms on its stand, stop turning and counting. The range is 3/4 to 1-3/4 turns. [] If fewer turns are required, you need a shorter pushrod, and a longer if more turns are needed"
Unless I've totally misunderstood, the last sentence is wrong, I think it should read "If fewer turns are required, you need a LONGER pushrod, and a SHORTER if more turns are needed".
Anybody agree with me? Is Tom Monroe on this forum?
