My pantera has the condensor and drier up the front, and a rotary compressor.
I took it to get regassed, and he said the high pressure side is blocked, or my compressor has died. Now it does work a bit, but not very much. the compressor spins fine etc.
Now I read the fantastic pantera technical pages and my diagnosis is the expansion valve ??
or this fine screen they talk about. Does that sound right ? if it is the screen will that show as blocked ? and can it be removed, cleaned, reinstalled and regassed ?
or do i replace the expansion valve ?? ( is that the same as the TX valve ??) lastly is this a Pantera specific item ? or is it a generic item ? We don't have any pantera shops down under !!
As always any help will be greatly appreciated
