Air Conditioning only has one speed-High. Shouldn't I have at least a 2 speed fan on my 74 Pantera? Attached is the back of my switch and circled is 2 empty tabs on it. Should there be something there? Thanks for the help Emery
It is a 2 speed blower, 4 wires to the switch, Brown: +12V, Black: Low Speed, Orange: High Speed, White with Black strip: Indicator light in speedometer. If the Black wire is not connected to the switch, Low speed will not work. I see only 3 wires in your image.
