Hi guys. I need some help.
I had a GM true 1-wire alt that I replaced. It worked fine but I had an intermittant drain problem and thought I would replace it. I bought a GM 2 wire alternator and wired it per drawing but the motor ran on with the key off. So I took it in and had it modified to be a true 1 wire alt. I tied #2 alt tab to blue/blk wire that goes to gen light. It still runs on until I disconnect the blue/blk wire.
Help
