Thanks everyone. I did connect the heavy Black & Red wires to bypass the ameter that I removed. For now its a #10 bolt with double shrink wraps. The voltmeter takes a acc wire for input.
Between the battery charghing system schematic and an older thread, volt gauge qustion, it made sense. Although my brain was saying don't connect red to black, that is exactly what to do.
The schematic shows them running to + on the battery, although the symbol they use looks like a ground at first glance.
The voltmeter is working great now.
On the new fuel gauge I added a 10 ohm resitor to mimic the fuel level when I made the swap. It's only one data point so I may increase the resistance later. For now the gauge is working.
Temp gauge appears to work so I'll leave that alone for now.
The oil pressure gauge reads 0, so I will swap the oil pressure sender (240-33 ohm?) with a vdo sender (10-180 ohm) to see if that fixes that.
The fact that I can see the gauges at night is so nice. BTW these gauges seem to be in limited supply. Black face, chrome bezels, slip right into the stock holes. The "spin-lok" mounting hardware is ok for the two middle gauges, but interferes top & bottom when trying to put the cluster back in the dash. I had to take the retaining rings off the back of the voltmeter and oil pressure gauges and rely on a friction fit for now. Thinking on a better solution without having to hack up the dash for more clearance.
VDO - Vision Chrome Series (being phased out?)
p/n 332-193 Voltmeter 8-16v
p/n 301-195 Fuel (240 - 33 ohm)
p/n 310-195 water Temp 100-250F
p/n 350-194 Oil Pressure 80 pis (10-180 ohm)
