Flywheel to Crank: 7/16" bolts: 60-65 lbs. 1/2" bolts 80-85 lbs. No washers. Pressure Plate to Flywheel: 3/8" bolts: 30-35 lbs. 5/16" bolts: 20-25 lbs. Use flat washers or bolts with the flanges. Also use some lock tight on all bolts. Feel free to call anytime Mark. Coz
Thanks Coz I almost called today but was having a hell of a time getting out the old pinion bearing in the crank. Is that what its called? So that took up must of my afternoon till I bought a slide hammer puller at Pep Boys still came out rather hard.
